B identity problem
Kevin
03-16-2002 16:30:28
I have a 1940 B it has a slant dash I was told that J.D. didn't make a slant dash in 40 in the B the serial # says its a 40 its a 4 speed hi lo with electric start and has a #10 carb I have a 41 with electric start but its a 6 speed hi lo its got the 34 carb which is right. help
Dean E
03-17-2002 04:25:36
 Re: B identity problem in reply to Kevin, 03-16-2002 16:30:28
I have a print out from Jd model B Changes of major parts says 1939 ser # 60000 tractor becomes styled, ser#60000tractors with starter have slant dash, ser#63479 Last aircleaner with two wingnuts It also says 1941 ser # 96000 6 speed trans begins and tractors with starters have straight dash. Note I got this info from another site,hope it helps. Dean
Will P
03-16-2002 17:59:48
Everything John F said is correct. Just confirming what he said.
Will P
John F
03-16-2002 17:12:45
Kevin,
John Deere did make the slant dash in 1940, I've got one also. I'm not sure if they made the slant dash in 39. They're kinda rare. 39 & 40 tractors have the 2 speed hi/lo transmision. The slant dash b's also had 7 inch lights.
Poor Farm Jim
03-17-2002 10:52:36
 Re: Re: B identity problem in reply to John F, 03-16-2002 17:12:45
John,
Did those 7" lights have flat lenses like the Oliver and M-M, or were they rounded?
Jim
John F
03-17-2002 13:08:51
 Re: Re: Re: B identity problem in reply to Poor Farm Jim, 03-17-2002 10:52:36
They're flat.
