2020 John Deere tractor won't start (gasoline engi
Chad
12-07-2003 17:05:50
I have a 2020 John Deere tractor with a gasoline engine that will not turn over with the key. I have replaced the solenoid, rebuilt the starter and replaced the switch. The dash lights come on when I turn on the switch, but when I turn the key there is no response. I can start the tractor by shorting the solenoid across, but that is the only way.
This all started when the starter began dragging. I went and had it rebuilt. When I picked it up, they had put on a new solenoid. When I hooked everything back up, it would not start unless I shorted the solenoid across.
Thanks for your help,
cd
Joe P.
12-08-2003 05:55:03
 Re: 2020 John Deere tractor won't start (gasoline in reply to Chad, 12-07-2003 17:05:50
Yes, check the neutral start wire connector (its on the right side of tranny below floorboard of my 3020) and the clutch depress safety connector (on left side below floorboard.)
Chad Detrick
12-14-2003 19:14:52
 Re: Re: 2020 John Deere tractor won't start (gasol in reply to Joe P., 12-08-2003 05:55:03
Sure enough, it was the plug on the neutral switch that had vibrated off. Funny how, with the timing of it all, it was something as simple as that.
I wasn't aware there was a plug under the floor plate. Thank you,
cd
Bob
12-07-2003 17:54:20
Your solenoid most likely has two small posts, labelled "S" and "I". The small wire to engage the starter, probably yellow, must be connected to the "S" terminal.
Do you have the transmission in neutral? Check for corroded terminals on the neutral start switch, or did the wire connector get pulled loose when you worked on the starter. Check with a test light to see if both terminals on the neutral start switch power up when you turn the key to the start position. With the tranny in neutral, the current should flow through the neutral start switch, and on to the "S" terminal on the starter.
