620 tractor
combine boy
03-15-2002 08:49:37
I have a 620 gas with a narrow frount end with no power steering and great tin. what i wanted to know is no power steering on a 620 rare?is it worth more to a collector with power steering on no power steering. this tractor also has new paint,3pt and power trol.
] Combine boy
Ray
03-16-2002 16:19:57
 Re: 620 tractor in reply to combine boy, 03-15-2002 08:49:37
A lack of options doesn't make a tractor more
valuable,although there were not many around,it's
not something anyone would hunt for,and a lot
would pass on.
Tony630
03-15-2002 19:23:23
My 2cents:
If you are satified with the tractor I would probably leave it the way it is.
If you are planing to operate on a daily basis that thing will wear you out without power steering.
Look at it this way - When you go to shows you have what I consider a unique piece. I don't know the last time I saw one without PS.
Tony
Tony630
03-15-2002 19:23:19
My 2cents:
Tony
POPPER DICK
03-15-2002 13:13:10
CB
I agree with Brian on it being worth more with power sterring. However, what you have to go through to repair the pump or motor assembly, might make you have second thoughts. I am just getting ready to tear mine down for repair.
When the front seal in the pump blows you are immediately in a cloud of smoke from the hot manifold and you and the tractor are full of power steering fluid. In my case thank goodness for glasses.
Dick
brian
03-15-2002 10:16:31
power steering is worth more!
Walt F
03-16-2002 20:31:47
 Re: Re: 620 tractor in reply to brian, 03-15-2002 10:16:31
john deere power steering good, char lynn power steering bad. don't settle for a after market power steering unit. they look bad, and tear up a manual steering system that wasn't designed for the extra torque of the power steering motor that mounts on top of the hood, just ahead of the steering wheel. my dad had one installed on his 60 back in 1970 used a oldsmobile steering pump that looked out of place under the hood that ran off the fan belt. he pulled a A.C. round baler three seasons before the steering gears wore out. the steering motor on top of the hood started to leak oil. it was a sad looking old tractor, and you couldn't go back and weld the steering shaft back together or fix the big holes drilled in the hood
