47 A brakes
Wes
12-07-2003 16:23:58
I started working on the brakes on my A yesterday so I could free up the adjusters (the brakes work fine and have plenty of pad left I was just bored). The right brake drum was held on with bolts but the left looks like it is riveted. Do I just grind off the rivets and use bolt to refasten the drum? I know it is a dumb question but I was already been told by a guy that I have screwed the tractor up by not doing everything to the letter of the JD law.
Wes
Spangle Washington
Clooney
12-07-2003 17:17:59
 Re: 47 A brakes in reply to Wes, 12-07-2003 16:23:58
Wes, that drum & shaft are held on with a nut from the rear... Just remove the 3 bolts & pull the entire brake assembly off the tractor.. Then remove the nut from the gear on the rear & pull the shaft out drum & all...
[email protected]
