A fuel filter
Larry T
12-07-2003 16:05:31
Three questions: 1950 "A" 1. Have a cast iron bowl on the fuel filter, is this correct and did they ever have the glass bowl. 2. I have changed the crankcase oil and filter and the oil pressure gauge show "H", is this OK or should it be adjusted to reduce the pressure. 3. I'm sure I've seen this answered befor but I can't find it. How do you remove paint from the tires. Can you use lye gravy?
Thanks for any help I can get.
Will P
12-07-2003 20:18:20
 Re: A fuel filter in reply to Larry T, 12-07-2003 16:05:31
Larry, are you sure that it is a cast iron bowl? I bought a 43A with a cast aluminum bowl. I asked on this board and a few people posted about the mounted picker just like Frank stated. Your tractor probably had a mounted picker on it.
Will P
F-I-T
12-07-2003 19:22:57
Larry:
On the paint on tires, I use Lacquer Thinner if it's a small amount, Lye Gravy if it's a large amount, and I have the tires dismounted, or on rims I intend to repaint. It's hard to keep the lye paste off of the rim and still let it set long enough to work. But the Lye Gravy REALLY cleans the old lamp black oxidation off of sun-bleached tires.
On your cast sediment bowl, I think those used to come with the installation kit for mounted cornpickers (226/227). The idea was that if you had a manifold/corn husk fire, the glass bowl could break from the heat, whereas the cast bowl might keep the fuel from the flames.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Larry T
12-07-2003 20:55:55
 Re: Re: A fuel filter in reply to F-I-T, 12-07-2003 19:22:57
F-I-T, thanks for the input.
Clooney
12-07-2003 17:14:47
Larry, you ask....
1. "Have a cast iron bowl on the fuel filter, is this correct and did they ever have the glass bowl"...>>>Answ, your tractor originally had a glass bowl..
2. "I have changed the crankcase oil and filter and the oil pressure gauge show "H", is this OK or should it be adjusted to reduce the pressure"...>>>Answ, that is probably normal.. Work that tractor hard for about an hour then see where your oil pressure is.. The hotter that oil gets the lower it will probably be..
3. "I'm sure I've seen this answered before but I can't find it. How do you remove paint from the tires. Can you use lye gravy"...>>>Answ, that lye would probably work but it is hard to control.. The best way I have found is to use some lacquer thinner on a rag & slowly work the paint off..
[email protected]
Larry T
12-07-2003 17:43:54
 Re: Re: A fuel filter in reply to Clooney , 12-07-2003 17:14:47
Thanks again Clooney for the help.
