720 questions
Kevin
03-14-2002 18:03:46
I have a 720 diesel standard with pto and dual hydraulics. I have started cleaning it up in preperation for painting. When I removed the flywheel cover, the casting was yellow. I was pressure washing it today, it is all yellow under the green paint. (it had been painted so time ago)
My question is, did JD make some industrial 720's?serial# is 7213883
Thanks
Steven M
03-14-2002 18:27:55
 Re: 720 questions in reply to Kevin , 03-14-2002 18:03:46
That yellow,is primer paint.
Frank-in-Tallahassee
03-14-2002 19:30:58
 Re: Re: 720 questions in reply to Steven M, 03-14-2002 18:27:55
I think it was used both as a primer and a casting sealer. Some machining operations will let their castings age, then clean them with shot peening or in a wheelabrator, then they'll paint them for protection during storage, and to make them easier to clean between operations as the paint sheds oils and water faster. It also helps fill any small sand pits.
Some of the car guys paint the inside of blocks with Alkyd (I think ?!?) enamel to promote the oil running faster back to the pan.
70D // 855
