Hercules Model L
John B
12-07-2003 15:37:12
I have a 1940 Model L with a Hercules motor that needs a piston. It is an aluminum piston 3.25inch that has been bored over 90 thousandths I believe. The top of the piston has 090 stamped on it. Can I find a replacement ? If so where should I look? Can one be made like it or should I buy two ?
Tractorboy
12-07-2003 17:05:03
 Re: Hercules Model L in reply to John B, 12-07-2003 15:37:12
John, you need to mic the cylinder and then you will know what size to find. Try Otto rings as they will have or make what you need. Link
Bob
12-07-2003 15:59:15
.090 or .060?
.060 would sure be a lot more likely.
John B
12-07-2003 16:24:43
 Re: Re: Hercules Model L in reply to Bob, 12-07-2003 15:59:15
Difficult to know. The piston has a stamp that says front with an arrow.pointing. When oriented properly to read this the stampped number reads 090. No decimal point to reference this number though.
HAVVEY
12-07-2003 19:11:15
 Re: Re: Re: Hercules Model L in reply to John B, 12-07-2003 16:24:43
TRY JOHN BOEHM OR RIDNORS
