49 A carb. settings
john
03-14-2002 16:58:46
I have A 49 A JD , I knew better but I did it anyway. Was plowing today trying to get A small miss out and I adjusted the carb. Now I have it so screwed up that it wont much more than run. My question is what are the starting settings, I had A book and I have lost it I think it was 1 1/2 turns on both jets but I am not sure. Thanks in advance
mef
03-14-2002 17:24:51
 Re: 49 A carb. settings in reply to john, 03-14-2002 16:58:46
According to the I&T Shop Manual for the model "A" is "Initial setting of idle needle when burning low cost fuel is 1 1/2 to 1 3/4 turns open for "A" series tractors. Initial load needle settings for low cost fuel are 1 to 1 3/4 turns open for Model "D"; and 3/4 to 1 turn for all other models. Settings for gasoline are slightly less, and final adjustment must be made for smoothest operation when engine is warm."
This is the way it is explained in the manual. Hope this helps.
jd
03-17-2002 23:43:57
 Re: Re: 49 A carb. settings in reply to mef, 03-14-2002 17:24:51
I and T is correct. One thing that might help you is to do them one at a time. IF carb is right you can turn idle jet all way down and it should idle due to bypass idle circuit in carb. start there then open up throttle and set fast idle. A stationary load is really beneficial when doing this.
