John Deere 401-B
Stan - Florida
03-14-2002 15:06:48
I saw a tractor today that I had never seen before. It was an Industrial tractor with the 401-B designation on the rear side of the hood. At first I thought it might be a 1020 or something like that, but it was bigger than one of those (I think).
Would this have been an Industrial version of a 3010/3020? It did have the hood lines of the 10/20 series New Generation tractors.
Thanks,
Stan
cannonball
03-15-2002 06:27:59
 Re: John Deere 401-B in reply to Stan - Florida, 03-14-2002 15:06:48
a 401B is not compared to a 2020 it is compared to a 2440 ..it has 62 hp and a lot heavier front end than a 2020..(have both)..the engine is a 219 mine has a pto and rockshaft..has a reverser on it..run a nine ft hd khun on it..have nice day
Stan - Florida
03-15-2002 18:10:04
 Re: Re: John Deere 401-B in reply to cannonball, 03-15-2002 06:27:59
cannonball,
Would the sheet metal on the 401-B have been a carryover from the 10/20 series tractors? The pictures of the 2440s that I've been able to find look like Generation II tractors.
Stan
cannonball
03-16-2002 05:35:01
 Re: Re: Re: John Deere 401-B in reply to Stan - Florida, 03-15-2002 18:10:04
yes they are have one piece hood and are all metal...have to be carryover mine is 1981...made in Dubuque ..they are good tractors.
Nathan(GA)
03-14-2002 19:50:20
I think Brandon is correct. Seems like it's the same as the 2020, but don't take that to the bank.
I think the 301 was same as the 1020.
I don't know about all the varieties, 01, 02 ect.
Stan - Florida
03-15-2002 04:22:03
 Re: Re: John Deere 401-B in reply to Nathan(GA), 03-14-2002 19:50:20
Nathan,
Thanks for the reply.
Stan
Brandon
03-14-2002 15:36:25
I'm not really sure, but the JD401B may be a later version of the JD400, which was based on the 2020. If you are interested, I have about 30 pictures of a blue painted 401B. It was on a website, and I saved every one!
As soon as the designations started getting beyond JD300, JD400, JD500, JD600, and JD700 I got confused. If anyone can explain all the different suffixes, and changes from the JD400 to the JD401, I would very happy.
Thanks and good luck,
Brandon "The industrial JD nut"
Stan - Florida
03-15-2002 04:20:47
 Re: Re: John Deere 401-B in reply to Brandon, 03-14-2002 15:36:25
Brandon,
Thanks for the info. It may well have been an industrial version of the 2020 that I saw. The color was an Industrial Yellow that sure could have used a wax job and might have then looked pretty good. It was a good candidate for that car wax they used to advertise as bringing back junkyard cars' finishes.
Stan
