G bearing Clooney
DOUG
12-07-2003 15:30:32
Unstyled G Reduction gear bearing loose in case, I have the tool JD used to cut it out and use a sleeve to drive back in. Do you have any idea whereas to where you would find those sleeves? I could go to a machine shop if I have to. Would I be better off going to JD to get trans bearing or bear bearing? THANKS DOUG
Clooney
12-07-2003 17:27:12
 Re: G bearing Clooney in reply to DOUG, 12-07-2003 15:30:32
Doug, I really don't know where you can find those bushing sleeves.. You might try Greg Stephen [303-663-5246] he has a lot of old unusual parts..
~You can try Deere for the bearings,, in a lot of cases the bearing are cheaper at Deere but do shop around as they can also be much more expensive...
~I always machine my own after boring the reduction cover out & measuring the bearing & hole I.D..
[email protected]
