AR Mag
Randal Simmon
03-12-2002 17:16:43
I'm in the process in restoring a 1939 AR. I took the mag off and found that it is not a wico mag but a Edison-Splitdorf Type CD mag. Can anyone tell me about this mag and is it a common mag for that tractor. Randy
Clooney
03-12-2002 17:46:54
 Re: AR Mag in reply to Randal Simmon, 03-12-2002 17:16:43
Randal, the Edison-Splitdorf CD is a gear reduction mag used on the early A's & AR's. According to my books the CD was used through about the end of 36 on the AR then the Wico AP was used. The info I have on the change is a little iffy so your tractor could very well have come with the CD. ~The CD is a difficult & expensive mag to gets parts for & if left on an unattended tractor could very easily come up missing.
~I have found the usual cause of malfunction on the CD is sticking, worn or broken little brushes in the dist block (cap) that ride on the contact rotor disk.
~If disassembled, the internal gear timing will have to be re-set so it fires at the correct time & the spark plug wires must be installed correctly due to the fact it doesn't fire on every revolution. ~The lag angle is not adjustable on the CD.
~This is a little overview of the CD, if you need any specific information or other info on the CD, E-Mail me..... .....
GPWT
03-13-2002 09:35:52
 Re: Re: AR Mag in reply to Clooney, 03-12-2002 17:46:54
If I correctly recall, the early AR/AO with the "oil peg" governor used the F-M #DRV-2A magneto, that changed to the F-M #DRV-2B magneto about mid-1936 model year. That was used until late '37. The Edison Splitdorf was used on some '37 or '38 A's, maybe it was also used on some AR's?
