2030 power steering
Bob K.
12-07-2003 12:57:59
Between the steering wheel and the main link that goes to the rod that goes forward under the console, there's excessive play. How do I access that - by the right side access port? Any suggestions on what it is? Also anyone know where I can check the serial number (online source, book, dealer?) to find out what year the tractor is? Thanks!
Brokenwrench
12-07-2003 14:09:16
 Re: 2030 power steering in reply to Bob K., 12-07-2003 12:57:59
There are 2 pop out plugs about 3'' in diameter on the left side of the casting. Behind frontmost one is the steering shaft with a bolt that holds the pitman arm on. you may luck out and the bolt has loosened up, or it may require replacement of the sector shaft and/or pitman arm.
