John Deere 730 hydraulics, have 2 need 4
Paul
03-12-2002 07:43:10
I have a John Deere 730 with 2 out lets, so you can run one double action cylinder. We just bought a new round baler and you need 4 hydraulic out lets. My questions is what is need to change it over? I found the box that goes on the back of the tractor so that you can run 4 outlets but do I have to change anything else? This will just be a back up tractor so if our main tractor goes down we COULD round bale with it. Thanks Paul
Bob Semrau
03-12-2002 10:17:52
 Re: John Deere 730 hydraulics, have 2 need 4 in reply to Paul, 03-12-2002 07:43:10
I have a JD 510 round baler that has the optional splitter on the baler. One pulls a rope to switch between the tie and bale chamber circuits. Maybe you should look for one of these.
Jhill
03-12-2002 10:04:23
I take it that you need to run two remote cylinders. You need a dual remote control box on your tractor. You will have a 3 pt control and 2 additional levers on the right side of the seat if you do. There are 2 angled pipe plugs in the face of the box. You need to replace these with hydraulic couplers. The is another setting to ensure that both cylinders are double acting. I would need my owners manual to be sure. I would get an owners manual it will give you all the information you need.
Jerry S
03-12-2002 08:02:02
I am sure you will need to have a way to control the valves separately or else you will dump your bale at the same time you go to tie it etc. I imagine that a dual control like goes on a front end loader would be useful but would require some creative plumbing.
