JD 50 Steering Wheel and Gear Box
Tye
03-11-2002 15:28:19
I need to take out the steeing wheel rod from the gear box on my john deere 50. How do I disconnect the rod from the grear box? Any help would be greatly appreciated.
BJ
03-11-2002 15:59:18
 Re: JD 50 Steering Wheel and Gear Box in reply to Tye, 03-11-2002 15:28:19
If it has power steering just remove roll pin from the coupler and pull out the back if it is manual steering you first need to remove the steering wheel and the woodruff key from the shaft then go to the front of the steering box and there is a oval shaped casting directly inline with the steering shaft should be held with two capscrews probably need 3/4 in. wrench remove bolts and can't remember which way to turn shaft for sure but this will push the bearing retainer out be careful not to drop the housing or bearing and pull the shaft out the front of gearbox
