JD 320 PTO Spindle Housing
Dugan S. Comer
03-11-2002 11:26:02
Anyone know where I can find a new or used housing
for the PTO spindle from a JD 320. The old housing is held to the back of the tractor with the use of three ears through which the bolts connect it to the tractor. My brother was using a bush hog and the torque was to much for the remaining ears and due to the fact that the housing is pot metal, it twisted and shattered the other ears. So, now we need a replacement. I have searched the "net" for a while, and this part is not to be found. If anyone has any ideas they would be appreciated, and if the part can be found close to or in Colorado that would be even better. Thank you all.
Paul
03-12-2002 17:57:15
 Re: JD 320 PTO Spindle Housing in reply to Dugan S. Comer, 03-11-2002 11:26:02
Dugan; I had a 320 with the same problem. I made new short "ears" out of angle iron and welded them on. It looks fine and it works fine too.
Paul
