JD R Pony bearings
smoker
03-10-2002 16:44:17
I was reading in my tech manual about the pony motor and it said that they do not make undersized main bearings for the crank. Is this true? The rear main bearing and main journal are grooved pretty deep. Does anybody have any experience with this?
Gpower
03-10-2002 20:34:27
 Re: JD R Pony bearings in reply to smoker , 03-10-2002 16:44:17
you can get .002, .004, .020, .022 undersized crank pin bushings/bearings for the pony. If not, then you have to have the crank welded up and then turned back to factory specs. Hows the R coming anyhow?? Like to hear from you,
Gpower
smoker
03-11-2002 05:51:58
 Re: Re: JD R Pony bearings in reply to Gpower, 03-10-2002 20:34:27
The R is coming slow. I got a set of pistons and I am going to take everything to the machine shop tomorrow I hope. I called the place that you said to call about the cam and they said that they had never worked with a R cam. They were pretty high on price for my budget anyway. Also, do you know what size of plungers and barrels that a 730 has? Will the pumps on a 730 bolt up to the pump bracket on an R? Talk to you later.
