450C JD Track adjuster
Larry
03-09-2002 15:33:12
I have a track adjuster keeps blowing seals, any suggestions on the best-cheapest way to fix it? Does anyone have one for sale?
Handsome Jim
03-09-2002 19:26:05
 Re: 450C JD Track adjuster in reply to Larry, 03-09-2002 15:33:12
Hi Larry, if you don't get any responses on this board, you might want to check the crawler discussion board. That's where I go with questions about our 455G. You don't see many questions about the 'newer' JD crawlers here. Good luck.HJ
JONATHAN
03-10-2002 04:42:44
 Re: Re: 450C JD Track adjuster in reply to Handsome Jim, 03-09-2002 19:26:05
Just checking ...but are the seals being installed correctly ??? make sure the lip of the seal faces into the bore of the cylinder on the end of the yoke..the outer dirt seal faces the opposite direction...The updated design adjuster has the seal on the inside of the bore of the yoke.
Richard
04-26-2003 07:54:33
 Re: Re: Re: 450C JD Track adjuster in reply to JONATHAN, 03-10-2002 04:42:44
I can't tighten my tracks by pumping greese, is there some way to tighten them or is there a trick that i'm not aware of,
