Advantage of LP distributor?????????????
Carl
12-06-2003 21:16:46
What is the abvantage if any of installing a LP distributor on a gas 2 cylinder John Deere?
Clooney
12-07-2003 05:27:40
 Re: Advantage of LP distributor????????????? in reply to Carl, 12-06-2003 21:16:46
Carl, it depends on what you are installing it on & what other modifications are done to that engine..
~The big advantage of those gear reduction LP distributors is that they run at 1/2 crankshaft speed & only spark every other revolution of the crankshaft..
~The real early Deere 2-cylinder tractors with the mag driven from end of the governor already had a gear drive [1/2 crank speed] mag so about all you gain there is the spark advance & a little stronger spark [you will also need a battery to run the LP distributor & find a way to mount the LP distributor on the early long lug governors].
~On the later 2-cylinder tractors that used the Wico C, or X [XH] mag you gain the automatic spark advance & the fact that the distributor only fires on the compression stroke. The spark advance is nice & does make the engine run a little better [but so will the regular distributor]... So what you gain here is a spark advance & again only firing on the compression stroke [only firing on the compression stroke takes some of the popping out of the engine exhaust]..
~On the later 2-cylinder tractors that have a cam driven vertical distributor on the crankcase,, they already have the 1/2 speed distributor & automatic spark advance so you gain nothing here [the LP distributor won't even fit these tractors without the older governors installed]...
~So that basically leaves us with charging system equipped Wico C ,X, or XB equipped 2-cylinder tractors [or tractors with low performance mags].. On those tractors with no engine modifications the LP distributor will make it run a little smoother with possibly a little less popping.. You will be able to feel [& hear] the difference but it won't be dramatic..
~OK, now for the ones it will really help.. Those are the MODIFIED 2-cylinder tractors with a governor driven mag/distributor & a charging system [basically a pulling tractor] .. On the engines with performance cams [with a lot of valve overlap] or higher compression, those LP distributors that only fire on the compression stroke can make quite a difference in performance & the way the tractor runs. If you have a tractor that would benefit from an LP distributor you probably wouldn't need this question answered...
~As stated above the big advantage to an LP distributor is: producing a spark ONLY on the compression stroke,,,a good working spark advance,,,a strong spark,,,a more reliable distributor..
[email protected]
OK-AL
12-07-2003 09:19:13
 Re: Re: Advantage of LP distributor????????????? in reply to Clooney , 12-07-2003 05:27:40
Clooney,
I have a 720LP. It has a vertical distributor. According to your above post, the later two cylinder LP models didn't have a LP distributor?
Just trying to figure out what it's supposed to have on it.
Thanks,
OK-AL
Clooney
12-07-2003 10:33:41
 Re: Re: Re: Advantage of LP distributor??????????? in reply to OK-AL, 12-07-2003 09:19:13
Al, the 720 LP used the same vertical case mount distributor as the 720 gasoline tractor.
The LP distributor we were talking about is the right angle drive, reverse rotation governor mount distributor [commonly called the LP distributor].. That was used on LP tractors prior to yours....
[email protected]
OK-AL
12-07-2003 16:53:09
 Re: Re: Re: Re: Advantage of LP distributor??????? in reply to Clooney , 12-07-2003 10:33:41
Thanks very much !!!!! !
