3010 JD running
BBhoward
03-09-2002 05:08:51
Backfireds though muffler and dies when idling seems to be starving for gas but put on rebuilt carb for 600.00 and doing same thing. seems to be getting plenty of gas through filter and pump need help????? ?????.
JNolan
03-09-2002 06:32:10
 Re: 3010 JD running in reply to BBhoward, 03-09-2002 05:08:51
Mine did that and after running new fuel line and other things I found old gas had hardened up in the inlet to the carb after the fuel line and turned to solid blockage inside the small screen filter. Had to take it out and wire brush and clean the screen.
Greg A
03-09-2002 06:24:26
My 1964 3020 was doing something simular to what yours was doing. Turned out that an intake gasket was sucked in and was letting air into one of cylinders. Installed new intake gaskets and ran fine then.
BIG JOHN
03-09-2002 05:39:39
Sounds like timing problem or stuck exhaust valve.
