430 steering question
Bguy
03-08-2002 18:57:57
I have a 430S that pulls to the left. It steers good other than that but when you are going down the road and let go of the wheel it immediately turns sharp left. Something in the frontend geometry needs adjusting but I don't know what. The tires are new and have equal air pressure. Anybody have a fix for this?
Clooney
03-09-2002 09:09:26
 Re: 430 steering question in reply to Bguy, 03-08-2002 18:57:57
Bguy, assuming you don't have a dragging brake on the rear you probably have a bent spindle, worn bushings or bent knee causing a caster or other geometry problem.
~Is the axle pivot pin fairly tight & the wheels, knees, spindles, hubs & steering arms the same side to side? Are the wheel bearings adjusted correctly on both sides? Check to see if the wheel bearings have worn into the spindle on either side. Are the steering arms installed at the same angle on each side?
~Try swapping tire/wheel assemblies side to side to see if that helps, if not look for bent or worn parts. Make sure the center of the tire is the same distance from the center of the spindle on both sides.
~If it has power steering post back as that introduces other variables.
Bguy
03-09-2002 11:20:02
 Re: Re: 430 steering question in reply to Clooney, 03-09-2002 09:09:26
Thanks for the reply Clooney, I don't have power steering. I am printing out your list of things to look at to take to the shop. I'll let you know what I find.
