jdemaris
12-07-2003 06:10:19
Re: 4020 steerin in reply to dan, 12-06-2003 20:39:29
Steering gets priortiy oil from the pump. So . . . it's possible if something is blown in the steering valve, nothing else would work. If I was working on it, I'd block the line going to the steering first. If the rest of the system still does not work, I'd do some external checks on the pump before pulling it. The most common problem, as long as you're sure the pump is actually turning, is the stroke-control valve. If it's badly worn, or if it gets a piece of debris in it, you can totally lose all hydraulics. It can be serviced without removing the pump. Sometimes you can just pull it out, clean it, and reinstall. If it's badly worn, you can install a new valve and seat, or . . . if it's not real bad, resurface it on a valve-grinding machine. I've done the latter many times and gotten years of service. Another quick check for pump condition is to pull out one of the eight pistons. Pick one you can reach easily. Usually, if the pump is really trashed, all the pistons will be badly scored and/or the springs broken. If you pull one and it looks pretty good, it's likely the rest will be also. Light scoring is okay. If you find that the steering valve is screwed up, then it's time to pull it and fix it. Not too bad to work on, but a pain to get out. Basically, there's a large piston with sealing rings, and four valves that must be operating and adjusted correctly. Sometimes the rocker arms that actuate the valves can break. There's lots more I could mention, but I don't want to start writing a new service manual.
