70 Gas Clutch problem
jdman(MO)
03-08-2002 16:46:36
Clutch started slipping today, and felt like it needed adjusting. By the time I got to the shop, it was hard to engage. Notice the setup is totally different than an A or B. How do you get to the fork and dogs. Russ
BJ
03-09-2002 15:45:28
 Re: 70 Gas Clutch problem in reply to jdman(MO), 03-08-2002 16:46:36
The 70 gas has an internal weight on the crankshaft so you do not have to worry about lining up the clutch driver the driver for your tractor is fairly thin due to crank being internally weighted
Clooney
03-08-2002 16:56:59
JDman, the fork is behind the big pulley seal cover (bolted on cover just behind the pulley), once the cover is unbolted & the pulley is off you will have to pull the big drive gear off the pulley to remove that cover from the pulley get to the "dogs".....
jdman(MO)
03-08-2002 17:42:24
 Re: Re: 70 Gas Clutch problem in reply to Clooney, 03-08-2002 16:56:59
Thanks going out now to take a look. Russ
jdman(MO)
03-08-2002 20:15:12
 Re: Re: Re: 70 Gas Clutch problem in reply to jdman(MO), 03-08-2002 17:42:24
Took everything but the pulley off, the last disc was oily, and the other disc showed uneven wear. Looks like the bronze bushing could stand replacing, but for the time being I am going to clean with Brake Cleaner and re-assemble. No V marks on the crank, but did see a faint punch mark. Russ
