Fan shaft pinion
Jd36
03-08-2002 09:54:12
I have a 1936 "B" and I need to replace the pinion gear on the fan shaft. I having a lot of trouble getting it off.
Any suggestions ????? ??
Clooney
03-08-2002 14:13:01
 Re: fan shaft pinion in reply to Jd36, 03-08-2002 09:54:12
Jd36, a GOOD 3 jaw gear puller & a little heat usually does the trick. Make sure you have removed the retaining ring.
JD36
03-09-2002 09:50:20
 Re: Re: fan shaft pinion in reply to Clooney, 03-08-2002 14:13:01
Thanks Clooney...you're a great help !!!!!
