John Deere 50, 60 info
Walt F
03-07-2002 20:43:36
Does anyone know what number is on the generator that would go on my "50" ser.#5016218. my tractor has an alternator rigged on it,and I'm going to a salvage yard this Sat. to get some parts. They don't have a 50 to part out but have some A and 60s and 620s. Are the spark plug covers the same? Are the flywheel center hole covers the same? Are the battery box and seat the same? I ordered a parts book from John Deere almost 2 wks. ago and they say they'll call me when it gets here. I want to get it running before I sink to much money into it.... thanx
DaveH
03-08-2002 19:29:56
 Re: John Deere 50, 60 info in reply to Walt F, 03-07-2002 20:43:36
Walt,
Both the 50 and 60 used the same flywheel hole cover - part # AB3579. I'm pretty sure that the 20 and 30 series used the same.
The battery boxes are also the same - part # AA7337R.
The spark plug covers are the same - left hand part #A4589R & right hand part #A4588R. At serial number 5018449 the spark plug covers were changed. Yours
should have a notch in them for the spark plug wire conduit to fit in. The later ones had a hole in them with a rubber grommit for just the wire to go through. I have seen where guys have taken the later style and cut the notch for the conduit.
If it's done right you can't tell the difference.
Poor Farm Jim is correct about the generator. an earlier style generator would work but it has a larger pully and the mounting bracket is different.
Good luck with your 50. I wouldn't trade mine for anything.
DaveH
Poor Farm Jim
03-07-2002 21:47:54
Walt, for your serial number the book calls for a D-R model no. 1100309 generator, which can be found on later 50's, 60's, 520-30, 620-30, 720-30 gas. The break on the 50's is no. 5016058. Oh yes, and on later 70 gas. Hope this helps.
Jim
