How to check injector pressure on 4020
David*
03-07-2002 10:53:07
I neeed informaion on how to check injector pressure (and what psi should it be?) and adjust if ecessary on a 4020 John Deere, please e-mail my address [email protected] Thank You, David*
Ray
03-08-2002 05:39:06
 Re: How to check injector pressure on 4020 in reply to David*, 03-07-2002 10:53:07
Unless it's an old 4020 the injectors are throw
away,only cost around 70 bucks.I have a tester
for the older style,but you still have to send
them out if there not working right.
G-MAN
03-07-2002 13:44:52
First of all, you will need a nozzle tester - better known as a pop-tester. You will also need the proper fittings to test the 4020 nozzles. If you don't have a pop-tester, my advice would be to just take them to your local dealer and have them tested. Testing nozzles can be dangerous if you don't know what you're doing - you can end up injecting fuel into your skin, not a good deal. If you do have a pop-tester, the opening pressure is 2500 +/- 50 psi. It should not open at less than 2400 psi. Also look for proper spray pattern and check tip leakage.
