JD D idler gear bushing
Marty Z
03-07-2002 04:40:44
The bushing is sloppy and I have a new one on order. I plan to cut the old one with a gentle hack saw blade and remove. I was told to heat the gear in the oven and freeze the brass bushing then slip the two together. Does this sound OK? How hot do I have to get the gear? Will it slip right in or do I need a press still? If I am way off base let me know..
Thanks
Marty
Clooney
03-07-2002 07:00:43
 Re: JD D idler gear bushing in reply to Marty Z, 03-07-2002 04:40:44
Marty, I always just press them in cold with a bushing driver using a little oil on each part.
~I think you will find that heating the gear & freezing the bushing will be a waste of time as the bushing is brass & pretty thin so the minute it touches the hot gear it will heat right up & expand also.
Marty Z
03-07-2002 07:39:51
 Re: Re: JD D idler gear bushing in reply to Clooney, 03-07-2002 07:00:43
OK, I was afraid of deforming the bushing with a press.I will be gentle . Thanks
Marty
