What color is a John Deere plow?(Molboard)
A-C Don
03-06-2002 18:39:37
What is the color of a JD steel wheel 1 bottom plows coulter blade and molboard, (black, silver, or JD yelllow)???? thanks, Don
Bob Collins
03-07-2002 05:14:04
 Re: What color is a John Deere plow?(Molboard) in reply to A-C Don, 03-06-2002 18:39:37
It depends on the age of the plow and the type of bottoms it has. The Syracuse bottoms on the older plows were silver and, when new, they had "Genuine SYRACUSE Deep Chilled" stencilled on in red on the point. Later, about 1953 when the newer type bottoms came into use, they were black on the front side and usually green on the back, having the bottom type stencilled on above the John Deere emblem. Bob
Stan - Florida
03-07-2002 05:49:48
 Re: Re: What color is a John Deere plow?(Molboard) in reply to Bob Collins, 03-07-2002 05:14:04
Based on the original question, I'd guess that his plow is older than 1953. Did all the plows have the Syracuse Chilled plow bottoms on them, or was that an option. I remember seeing that name/description, but don't remember the details.
Stan
ET
03-07-2002 07:01:15
 Re: Re: Re: What color is a John Deere plow?(Molboard) in reply to Stan - Florida, 03-07-2002 05:49:48
Plow bottoms are interchangable on the frames. The dealer ordered the plow frames in and put on whatever bottoms suited the soils and conditions in his area.
Stan - Florida
03-07-2002 08:37:22
 Re: Re: Re: Re: What color is a John Deere plow?(Molboard) in reply to ET, 03-07-2002 07:01:15
Thanks for the reply. I think "chilled" must have been a manufacturing or hardening process, as Oliver used to advertise their plows that way.
Stan
ET
03-07-2002 11:31:32
 Re: Re: Re: Re: Re: What color is a John Deere plow?(Molboard) in reply to Stan - Florida, 03-07-2002 08:37:22
Chilled iron has better wear characteristic's than other steel available at the time these old plows were made.
SteveA
03-06-2002 20:38:04
The manual for the JD 44 plow says that "the polished surfaces of the plow bottoms are varnished, and those on the coulters and jointers are blue lacquered. this protective coating should be removed before using"
Stan - Florida
03-07-2002 04:07:12
 Re: Re: What color is a John Deere plow?(Molboard) in reply to SteveA, 03-06-2002 20:38:04
If you want the plow to look like it just came from the dealer, go with what Steve says - that's how they looked new.
If you want it to look like it's ready to be put away for the winter, get those parts scoured down to bare metal and put a coat of grease on them with a rag or a brush - that will look authentic!
Stan
Well then anything but yellow
03-06-2002 19:43:55
Black would in my opinion look the best. As some farmers use black protective coats on their moldboard and shovels now.
A-C Don
03-06-2002 18:58:53
I know it should be bare guys, but this old plow will not see anymore fields.
BJ
03-06-2002 18:55:21
I usually paint them black when done using plow
Richard
03-06-2002 18:44:29
The business side should be bare.
