Heisler head on late A
JDBert
03-06-2002 11:16:37
Anybody ever put a heisler head on a late A. I have a 51' with .125 over bore pistons, M&W style. Any mods or do they just bolt up. How about parts for the head available or hard to get? How about horsepower gains?
WTW
03-07-2002 08:11:37
 Re: Heisler head on late A in reply to JDBert, 03-06-2002 11:16:37
Bert, To put the late Heisler on a 51 "A" you will need to get the longer head bolt studs from an older "A" (1940-1946). The Heisler is a thicker head like the older tractor it was intended for. I also switch the push rods. Check a parts book but I think if I remember right the rocker arms are the same. If not switch them too. Most all Heislers that I have put on tractors I put on Power Blocks with custom pistons. If you are putting this head on stock M&W pistons you will want to cut the tops down if you are wanting to run stock fuels. They will knock if you don't. Good racing fuel will keep it from pinging if you want that type of engine compression. The biggest thing that you may need for parts for the late "A" Heisler head is valves and stock John Deere "70" gas valves will work in them without any modification. Good Luck, Dave W.
