3010 w/ 36 tires -help
Ken
03-04-2002 13:21:24
I have 36" tires on but need new ones and they only come in 13.6 vs 14.9 that are on now. The 13.6 looks to small. What can I do? Are there wedges avail. so I can replace the 36 w/ 38" rims?
doug
03-05-2002 08:06:09
 Re: 3010 w/ 36 tires -help in reply to Ken , 03-04-2002 13:21:24
Have a 520 that I converted to 38" rims. There are no wedges or step up rims out there thaat I found. Take a 38" rim and weld 8 or 10 or whatever the number of 3" pieces of 3X3 or 3X4 angle onto the rim to match up with the studs coming out of the cast hub. You'll probably have to take your hub off and lay down in your rim once the pieces of angle are welded on to get your bolt pattern right. Mine turned out real good, can't really tell it's not factory unless you knew.
Craig
03-04-2002 15:14:30
Ken, Good Luck! , We just change a set on a 3010 and would'nt you know it they dont make them any more. Sooooo we had to change tires and rims. Good Luck! Craig
