JD 8875 Skid Steer
Junkman
03-04-2002 12:36:56
I have an 8875 JD skid steer taht keeps dying on me. All I have to do to get it running again is bleed the fuel system completely. I have replaced the small fuel filter and put some additive in the fuel tank to prevent gelling (as the high today was in the teens). After bleeding the fuel it will run great for about30-45 minutes. Anyone have any suggestions?
Brokenwrench
03-04-2002 17:10:02
 Re: JD 8875 Skid Steer in reply to Junkman, 03-04-2002 12:36:56
We have 2 885 NH (same machine different decals) that did the same thing. One had a bad fuel pump, the electric transfer pump, the other one had a faulty fuel cap. Try running the machine with the fuel cap loose, and see if this doesn't straighten it out. The cap is vented and if it won't let any air in, the transfer pump can't supply fuel to the injector pump. Hope this helps.
