Flushing transmission
Dave / Believer
12-06-2003 14:36:50
I am in the process of flushing the transmission on my 2010 with diesel fuel and wondered the advisability of using a water dispersant / diesel fuel additive like you would run through a tractor-trailer diesel engine on a cold day. Would this help get the condensation out of the transmission and hydraulic system?
Thanks in advance for your help.
Dave / Believer45
Dave / Believer45
12-06-2003 20:24:00
 Re: Flushing transmission in reply to Dave / Believer45, 12-06-2003 14:36:50
I posted on another site as well - there seems to be some concern with diesel fuel and the hydraulic pump & seals. Do I need to be concerned about lower lubricity on the fuel vs. HyGuard and such?
Dave / Believer45
Dave / Believer45
12-06-2003 20:15:34
Dave / Believer45
Brokenwrench
12-07-2003 14:41:22
 Re: Re: Flushing transmission in reply to Dave / Believer45, 12-06-2003 20:15:34
I wouldn't worry about lack of lubricity. Even if you drain the tractor overnight, there will still be several gallons of hyd. oil in pumps lines, valves etc. Flush it with fuel, drain overnight,dump 5 gal.of cheap hyd.oil in it cycle all your hyd. functions and drain again and refill with whatever fluid you are going to run.
F-I-T
12-06-2003 20:24:57
Dave:
I've never had a problem with that, and I've done it dozens of times. Diesel fuel lubricates the seals in the fuel pump very well, and has lot of lubricity. It just likes to foam in an open system, and has a lower boiling point than standard hydraulic fluid so it will gas off a bit, or it would make a good, albeit thin, hydraulic fluid.
Remember, it gets pumped up to 2400 psi in the diesel injection system. That's pretty hydraulic.
If you're nervous, use some cheap hydraulic fluid and throw it away.
Frank
Dave / Believer45
12-07-2003 09:37:55
 Re: Re: Re: Flushing transmission in reply to F-I-T, 12-06-2003 20:24:57
Frank, thanks for the advice. I was under the same impression as to lubricity of the diesel fuel. I will not be doing anything with the hydraulics except running them up and down a few times to get the contaminated oil out. I will be goin to get the fuel and do the job this afternoon.
Dave / Believer45
F-I-T
12-06-2003 18:23:51
Dave:
I'm not sure that's really necessary. The diesel fuel will drive the water out of the nooks and crannies, and then the water will head to the lowest point because it's heavier than the diesel fuel, so it should be the first thing to come out via the drain when you dump it.
Frank
