G-Head
Randy
03-03-2002 17:15:21
I have a J.D.'G' Head #F486R. It is flat accross the face of the head,Is this a high comp.head?This is differnt than the head on my G now. Thanks
JDGnut
03-04-2002 07:12:13
 Re: G-Head in reply to Randy, 03-03-2002 17:15:21
Like Gman said.. the F486 head.. is the flat head.. it is the head that was used on the Unstyled G's.. The compression is going to depend on what tractor, block and pistons you have in your tractor... If it is an unstyled G, that is the correct head for an unstyled G block. (the unstlyed G block is 1 in longer than the styled block.) If the flat head is installed on a Styled G with the Styled G block the compression will be increased.. How high the compression, will depend on the style of pistons in the tractor. Flat pistons, with the flat head on a Styled G, pump gas.. Flat head and high compression pistons.. 100+ octane fuel or LP... Good luck
JDGnut
Gman
03-03-2002 17:44:38
Randy if its flat and F-486r is on it you have a flat head. Later Gman
