JD410-D
Mike
03-02-2002 23:05:50
My backhoe will shift into reverse with plenty of power But all of a sudden it will stall the engine.
It has no power with the lever in forward and won't send fluid to the brakes. I know it needs work, but since it is mid 70's I would like to restore it. The backhoe has power but the loader has very little. Help!
Jonathan
03-03-2002 05:25:01
 Re: JD410-D in reply to Mike, 03-02-2002 23:05:50
Not sure what you mean by not sending fluid to the brakes...I would take apart the shift control valve first to see if there is a blown out gasket that is misdirecting oil to the forward and reverse clutches at the same time...If it was just a lack of forward power (slipping) then I would guess that the sealing rings that connect the oil passage to the forward clutch pack are worn....a common occurence....
...as far as the weak loader hydraulics...that is unrelated as that is due to low front pump output pressure....but maybe the pump is worn due to the reverser coming apart ...all the same oil....internet diagnosing isn't the easiest thing to do !!!
