2010 building pressure in transmission
Dave / Believer
12-06-2003 12:09:24
My new (to me) 1961 or 62 2010 is building pressure in the transmission. When I pulled the plug to drain it the oil shot out pretty hard then, after some had drained, it "glug-glugged" to let air back in while draining.
I assume there is a vent somehwere. I have looked in the John Deere parts catalog and cannot find one. Can anyone tell me where it would be?
Thanks -- Dave / Believer45
HTR
12-07-2003 15:06:02
 Re: 2010 building pressure in transmission in reply to Dave / Believer45, 12-06-2003 12:09:24
Look behind the seat on the top of the rockshaft housing. The early 2010s the breather was a wire mesh type thing, located under the bracket, that the center link, of the three point hitch stored on when not in use. Two bolts take the bracket off, and dig the screen out and clean the hole under it. The later ones had a small breather about the size of a silver dollar, behind the seat, on top of the rockshaft housing.
DON
12-07-2003 14:50:25
The filler cap is a vented cap, just blow and wash till it breathes. Don
jdemaris
12-06-2003 15:12:56
Do you have a wheel tractor or crawler, and does it have a collar-shift transmission or an H-L-R?
Dave / Believer45
12-06-2003 17:46:06
 Re: Re: 2010 building pressure in transmission in reply to jdemaris, 12-06-2003 15:12:56
Wheel tractor, not sure what you mean on the transmission - it has eight forward gears and three reverse, shift lever in the dash that works in clusters of two forward, one reverse except highest range (noreverse in the road gear range).
