Float ride seat and EPOXY
MIKE HANLEY
12-06-2003 11:14:09
Recall I had the 630 float ride seat done last month with new rubbers, new bushings and new shock. Plus the seat cushion with the springs instead of just foam. I drove the 630 14 miles to the JD dealer when it went in get the Elec Ing put in and I was inpressed! As was the shop guys and many two banger owners that also sat in the seat. While the 730D Is layed up I thought I would sent out that seat. Got it back in 7 days. There is a piece of tin across the front and the rear of the seat on the 730 that were rusted and bent. Also over the rubbers is is a piece of tin where the decal goes the shows how to ajust the seat. That was all banged up from the upper link of the 3 PT. The two cross pieces of tin were spot welded in places and when I got the old tin off there was a lot of rust under the tin on the frame. Whent to the local steel supply shop and he cut me the 3 pieces out of 1/8" steel on the band saw to fit with the curves. Navel jellyed the rusted part of the seat frame and then used LOCTITE QIUCK SET EPOXY (part TM-51 81502) to "glue" the pieces to the seat. Never used that stuff before. Have used JB WELD for years and always have that on hand. Now I will always have this EPOXY on hand also. By using the EPOXY all the way around the seat frame there is now a seal that will prevent rust from forming between the metals. Maybe this will give someone some ideas.
