L bryan, basically because it has what's called BY-PASS starting on it.... ~The 6 volt coil using an external resistor is used to keep the points current at under 4-5 amps & still allow easy cold starting... ~Most 12 volt cars, trucks, & tractors built after the late 1950's use a 6 volt coil & "by-pass" starting.. ~You will also find a resistor on your tractor [either at the ignition switch or a resistor wire from the switch to the coil].. There will also be a by-pass wire running from the starter to the coil.. ~Your system [ & other by-pass starting systems] use a 6 volt coil with a resistor that drops the coil's running voltage to around 6-8 volts during operation.. During the starting process 12 volts [actually system voltage] is run directly to the coil so the spark is intensified for starting].. Then when the starter is released the coil reverts back to the resisted 6-8 volts to run on & protect the points from high current.. ~The reason for the by-pass starting is because if a 12 volt coil was used the voltage to the coil during cold engine cranking could be a low as 9-10 volts & as you could imagine that would produce a pretty pathetic spark.. ~Even most 12 volt coils [the ones that say 12 volts on them] have an internal resistor to lower the current going to the points.. The problem with those internally resisted 12 volt coils is there is no way to increase the spark output during cold cranking.. ~That by-pass starting using 12 volts on a 6 volt coil was one of the greatest things to come along for low battery or cold weather starting.. [email protected]
