HELP PLEASE, need advice on 1937 B
Chuck McDonald
03-01-2002 20:01:19
Hi,
I have a 1937 B short frame and i am having an oil leak from between the block and main case. The problem I am having is that the tractor has had a 1K paint job that is slicker than snot put on last year and i really hate to do anything to it. I ordered a new gasket for that as well as for the valve cover. What i want to do is this:
1. leave the tractor asembled as much as possible.
2. lave as small of a mark as possible on my EXPO paint job.
So, what i am getting to is i want to pull the inspection plate, pull the rod caps, slide the pistons forward in the block, pull gas tank etc to get to the engine, leave maifold on, unbolt the block/head assembly and mearly pull the whole thing forward in the frame, put the new gasket on and then shove it all back together and reconnect the rods/rod caps in one fell swoop. Is this possible or mearly wishful thinking. Is there anything else anyone who has done something like this before can suggest or give me tips? I hate to do this but if i am going to have my tractor in the JD collectors center this fall i want it to be "right." Plus i dont like having a huge puddle of oil under my tractor in a parade after sitting for 4 minutes!
SOMEONE HELP ME PLEASE!
Thanks in advance chuck mcdonald
Will-Texas
03-02-2002 08:38:48
 Re: HELP PLEASE, need advice on 1937 B in reply to Chuck McDonald, 03-01-2002 20:01:19
Chuck; you might want to check out Cloonie's response to "H oil leak" a couple pages back.
ET
03-02-2002 04:45:58
You might pull it off its worth a try. Consider cutting the gasket on the top side to help get it in then use a little silicone where the seams come togeather. It can be done on an R this way
without unhooking the rods. Good Luck
