310 B John Deere Backhoe
Mountain Man
03-01-2002 19:47:26
Recently I ask for help with a hydraulic problem... Someone suggested I clean the screen in the transmission case. I did . It was full of metal. I am not a good mechanic, but I know this is not good.
When I first start the machine and the oil is cold, it all works fine. When it warms up, it is jerky when I raise the front bucket. I assume the pump is bad, and this is where the metal came from. some of it was a yellow or, copper color. Any help would be appreciated. thanks bob
John Henry
03-02-2002 04:12:33
 Re: 310 B John Deere Backhoe in reply to Mountain Man, 03-01-2002 19:47:26
Chances are your main pump is shot. But thats most likely caused by a problem elsewhere. Depending on what options your 310 is equiped with will help narrow down your search. The metal can be caused by extremely worn brakes, beyond worn out reverser clutchpacks, destroyed difflock and simply a ground up transmission and differential. Once the mechanical problems are found and fixed the hard part will be cleaning out all the hydraulics and hydraulic actuated equipment. If you dont get all the crud out of the system it will pollute and ruin all of the repairs you mite have accomplished. There is a good possibility that the parts cost alone will make this financialy prohibitive.
