36 A O fanshaft
RON
03-01-2002 10:07:39
Fan turns a revolution sticks and turns another did As have gear or other related problems.THANKS RON
Clooney
03-01-2002 14:20:40
 Re: 36 A O fanshaft in reply to RON, 03-01-2002 10:07:39
Ron, when the you say sticks do you mean the fan stops turning? If so can you tell if just the fan blade stops or does the fan & fan shaft stop together? (that will be hard to tell).
~If just the fan blade stops & not the shaft, it either has a slipping or worn friction clutch (If it has been fitted with the later friction clutch) or a worn & slipping rubber center in the fan (if it has the original rubber centered fan).
~If both the fan & shaft stop at the same time you probably have severely worn fan shaft drive gears at the governor end.
~Grab the fan blade & try to turn it, then move the flywheel a little & try again. If you find a spot where it slips reach in with the other hand & see if the fan shaft is turning also, if so check the drive gears.
