Clooney
re: Oil Filter Can tightening pressure
POPPER DICK
02-28-2002 18:32:36
Clooney,
In your reply to Joe and his 46B oil pressure problem you indicated one thing I'm currious about. I guess you can over tighten the bottom nut when installing a new filter. What is the proper tightening pressure for this maintenance item.
Thanks in advance
Dick
Clooney
02-28-2002 18:51:00
 Re: Clooney - re: Oil Filter Can tightening pressure in reply to POPPER DICK, 02-28-2002 18:32:36
POPPER DICK, I've never seen a tightening torque for that nut but it should be just tightened enough to not leak.
~The problem usually starts when the original "O" ring isn't removed & a second one is put in the groove, it takes overtightening to get it to stop leaking & that will warp the top of the filter body.
POPPER DICK
02-28-2002 19:04:59
 Re: Re: Clooney - re: Oil Filter Can tightening pressure in reply to Clooney, 02-28-2002 18:51:00
Clooney,
Thanks, I just changed my oil filter and replaced the botton gasket. Just didn't want to over tighten the big nut.
Dick
