Can I pull an 8 foot tandem disk with a 1952 Model B?
Bob Weber
02-28-2002 07:37:46
I'm wondering if it is too much disk for a B. I'd appreciate any feedback. Thanks!
Don
03-01-2002 16:32:19
 Re: Can I pull an 8 foot tandem disk with a 1952 Model B? in reply to Bob Weber, 02-28-2002 07:37:46
Dad had a 1941 B JD and pulled a 7 foot tandem disk. It was a heavy disk and the B handled it O.K. Your 1952 B is quite a lot heavier and has quite a lot more horsepower so should handle and 8 foot in good shape. HTH Don
POPPER DICK
02-28-2002 18:18:19
Bob
As a boy between 1947 & 1951 I pulled an eight foot four way with a nine foot three section spring tooth drag behind it with a 1947 model B and later a 1950 model B in third gear. We had flat good loam ground with some muck ground. I had no problem doing that. I don't remember the disk diameter but I think they were around 16 inches.
Good luck
Dick
Handsome Jim
02-28-2002 18:15:32
Bob, we used to pull 7 and 8 footers with a 50 without much problem, it all depends on your soil conditions and how deep you want to cut. The more weight you put on your disc, the more muscle is going to be required of your B. I never was a big believer in working the guts out of any tractor, especially an old one.HJ
