Powershift creeping in N
AJ
02-27-2002 17:48:02
4640 powershift creeps in both forward N or backward N when shifting out of park. what do you guys think? minor adjustment or major $$$ thanks..
Ray
02-27-2002 20:11:53
 Re: powershift creeping in N in reply to AJ, 02-27-2002 17:48:02
That's normal they all do it.I've got a 4440
we bought new that has always creeped in neutral.
twopop
02-27-2002 18:08:39
probably major money lest you do it yourself.your clutch discs are warped
G-MAN
02-28-2002 13:48:22
 Re: Re: powershift creeping in N in reply to twopop, 02-27-2002 18:08:39
This creeping is not normal. The tractor will creep if the oil is extremely cold, but shouldn't otherwise. More than likely you have a clutch pack problem, warped disks, or the pressure is not being released completely. Does the tractor creep with the clutch pedal down? If it does, you more than likely have a clutch pack problem. This requires the tractor to be split. Also inspect the flywheel damper at this time. We also install a new rear main seal when we are at that point. Just cheap insurance. Hope this helps you out.
