JD-A magneto
Charlie
02-26-2002 15:45:22
Took my A to the county fair to show it and
didn't cover the magneto,now it wont start,
took the cover off and it was full of water
tried to dry it out but still wont start,is
there anything I can do or have I ruined my
magneto?
Clooney
02-26-2002 16:02:25
 Re: JD-A magneto in reply to Charlie, 02-26-2002 15:45:22
Charlie, you probably haven't ruined your mag. Clean the cap & rotor real good with brake clean, then leave the cap off with the tractor in the sun for a few days or pull the mag & blow it out with (LOW PRESSURE) compressed air or a hair blow drier. ~The coil might still be wet, or the points might be oxidized causing your problem. It could even be wet wires in the wire tubes, or you could have fouled the spark plugs while trying to start with the wet mag.
~You didn't say what kind of mag & if not a Wico you might want to be very careful while working with it as some parts for the Edison-Splitdorf or Fairbank-Morse are almost impossible to find.
~It probably would be a good idea to install new spark plugs just to eliminate that, then test for spark with a bent wire right at the mag cap to eliminate wet plug wires & to see if the problem is actually the mag & not something else.
