Clooney/John T
Ed
12-05-2003 18:17:12
I now realize that part of my problem was the fact that my flywheel does NOT have anything on it that reads "L/H impulse. That's why I was a little confused. With the pin out, I turned the crank til #1 was at TDC,(I still have the crankcase cover off so this makes it easy.) I then installed the flywheel with the timing punch mark at 6 o'clock. I put the governor back on and lined up the marks on the governor/cam gears and guess what? Yep, the slots for the mag were horizontal! GO FIGURE! Something else interesting is that there is a "V" mark on the inside of the flywheel next to the crankshaft. Well, it just happens to point to the spline that I took the pin out of.
Someone (JT I think), wrote that if the flywheel is on incorrectly the tractor will vibrate. Well, thinking back when the tractor was running, it ran well, but it did have a significant amount of vibration. Easy fix if this doesn't work, but I really believe you guys fixed the problem!
Thank you again.....you'll be hearing from me again I'm sure.
Clooney
12-05-2003 20:04:41
 Re: Clooney/John T in reply to Ed, 12-05-2003 18:17:12
Ed, it sounds like you are on the road to victory..
~That L/H impulse isn't on all of the later flywheels [that is why I also mentioned that flywheel slot being horizontal when the L/H piston is at TDC]..
~Something you need to make sure of [seeing as you moved the flywheel] & that is that the drive pin on the back of the flywheel is engaged in the flywheel spacer slot.. When the flywheel was moved the spacer slot must also be moved to line up with the flywheel pin [is it?]..
~On the engine vibration, that will probably at least get better now that the flywheel is installed correctly.. The heavy part on the flywheel needs to be exactly opposite the crank throw on the flywheel side [that is easy to check now that you have the crankcase cover off].. It might still vibrate a little as the original flywheel was balanced as an assembly with the crankshaft & pistons but it will be a lot better than it was..
~If this was your first visit to this site come back & visit often...
[email protected]
Ed
12-06-2003 07:19:44
 Re: Re: Clooney/John T in reply to Clooney , 12-05-2003 20:04:41
Yes, the spacer notch got lined up before I put the flywheel on.
As far as the heavy side of the flywheel, are you saying that it is where the LH impulse would be?
The next time I work on it I'll be putting the clutch on and will see where the heavy side of the disc is in relationship to the flywheel. Actually, I guess with the (clutch) marks lined up it must position the heavy side of the clutch drive disc in sync with #1 crank throw.
Not new to this board. I've actually been around quite a while but find most of my questions answered from the archives.
Clooney
12-06-2003 08:00:59
 Re: Re: Re: Clooney/John T in reply to Ed, 12-06-2003 07:19:44
Ed, you ask...
>>>"As far as the heavy side of the flywheel, are you saying that it is where the LH impulse would be?"...>>> Answ. Yes, the L/H impulse writing would be on the balance weight side & in line with the flywheel slot.. Remember that extra weight off-sets the crank throw.. SO, piston forward [@ TDC] = crank throw forward & crank throw forward = balance weight to rear..
~On the clutch disk,, yes just line the >< marks up...If they aren't there install the disk with it's heavy part opposite the R/H crank throw,,,or with the L/H [flywheel side] piston all the way forward the counter weight on the clutch driver is also forward..
~In original form the balance weight on the clutch driver is 180� opposite the flywheel balance weight but that isn't a good way to look at it.. If for some reason the flywheel is incorrect [or installed wrong] the clutch weight will then also be off.. Those balance weights should just be placed to the rear with the piston on that side all the way to the front..
[email protected]
John T
12-05-2003 19:37:24
Way to go Ed, if the governor shafts female slot is flat horizontal fore and aft when the left piston is at TDC, a mag or distributor inserted therein can be timed to make her run so long as the cam and valves are in time also. On the clutch drive disk there may be matching V's indicatign its correct spline and like we all told ya regardless THE HEAVY SIDE OF THE FLYWHEEL AND HEAVY SIDE OF CLUTCH DRIVE DISK MUST BE 180 OPPOSITE or she vibrates. Thats why they BOTH gotta be on their right splines.
John T
