A question again regarding rods this time
Luke
02-25-2002 13:35:03
Hello again, while I'm on the subject of my A, I was wondering if the connecting rods from a later model A w/the bearing inserts instead of babbet bearings like mine, will fit in my A. The serial # of my tractor is 503802. I was curious because one of my babbets is chipped and I would rather put new bearings in the rods if I could. Thanks to all who can help. Luke
Charles Babcock
02-26-2002 20:08:57
 Re: A question again regarding rods this time in reply to Luke , 02-25-2002 13:35:03
Yes you can but you should have the crank miked.We do this to G's but we always take the crank and have them turn to 010 under
Dave K (Fl)
02-26-2002 15:34:18
I have had many old engines from cars and tractors with babbit bearings. In my experiance they often have chips and imperfections in the babbit but as long as the bearing wear surface itself is smooth and as long as they maintain oil pressure they will work fine for years. My 1948 A has babbit bearings with a few nicks in them but I still work the tractor pretty hard with no trouble.
Dave
dave
Larry M
02-26-2002 08:15:32
Luke, I have a 1945 "A" that someone has put JD-60 rods in and it runs fine.
Larry M
02-26-2002 08:15:16
Glen
02-25-2002 19:16:02
If you do end up re-babbitting your rods, get a price quote in writing before you send them off. I Didn'y with RAM and it cost me another $50 that I wasn't expecting.
Phil
02-25-2002 17:49:46
I swapped the babbits in my 1950 A for insert bearings out of a 51 or 52 A and they have worked just fine for me. Just my 2 cents.
Tractorboy
02-25-2002 15:45:31
You better watch it real close because the radius's on the old rods may not be like the insert type and then your rods will wander so check real close if you go to inserts . There r real good people out there that can redo your old ones like new too.
Frank-in-Tallahassee
02-25-2002 16:11:33
 Re: Re: A question again regarding rods this time in reply to Tractorboy, 02-25-2002 15:45:31
Tractorboy:
I thought the side play of a rod was determined by the thickness of rod boss vs. the width of the rod journal. I didn't think the radii controlled that at all. I'm pretty sure they don't ever touch.
Have I been wrong on this all along ?
DougS
02-25-2002 17:16:55
 Re: Re: Re: A question again regarding rods this time in reply to Frank-in-Tallahassee, 02-25-2002 16:11:33
No you are not wrong Frank..just add diametral clearance in addition to thickness of rod boss.
Jerry S
02-25-2002 15:02:28
The other post was a good one but I read a post a while back about babbit bearings that said some babbits might be just fine even if there does appear an imperfection in it. I guess that wasn't all that uncommon in the babbits and the suggestion was made that it was still smooth and had ran that way for many years under load so would still hold up. Of course if it was causing some problem on the crank journal, that would not apply.
ChuckW
02-25-2002 13:59:53
I believe the rods from 60 JD with inserts are the same diameter as the A crankshaft. Just excange rods, add bearings and you should be in shape.
