Hauling steel wheeled tractors
Bguy
10-16-2003 09:39:25
I bought a new JD B the other day and it's the first one I've had with steel wheels. I loaded that thing in the dark to take it home and, let me tell you, it was a pretty scary undertaking. Those steel wheels on the steel angle irons ramps and the wood floor was like being on a solid sheet of ice. Getting it up the ramps was an experience and then after I got it up on the deck it spun to the right real hard and fast for some reason. I was able to catch right before it went off the side but it took a couple years off of my life and at least that much off of my friend that was helping me. One of the brakes was dragging and making it extra squirrelly. I was sure glad to get it loaded with everything and everybody in one piece. (anybody want to buy some good steel wheels?) What kind of ramps do people use when they haul a tractor on steel?
Daryl
10-16-2003 13:12:51
 Re: Hauling steel wheeled tractors in reply to Bguy, 10-16-2003 09:39:25
Steel Wheels and trailers are very dangerous! A winch is excellent to load steel wheeled tractors. A rollback truck with a winch is even better!
JDBob
10-16-2003 10:22:27
Bguy,
We made 3/4 inch plywood inserts that would lay down on the ramps, just narrow enough they kind of snaped down between the two outer pieces of iron. Then found some old (Thick) conveyor belt and cut pieces that we bolted to the plywood, used long enough bolt that they would catch on the angle rungs of the ramp to keep the plywood from kicking out from under the steel lugs. Then we use more of the coveyor belt rubber and made long runners to lay on the bed of the trailer for the wheels to run/set on. This worked out great, no slipping, no busting boards.
JDBob
