FH Spoke wheel tire size
Bguy
02-24-2002 17:13:18
I have a set of F&H round spoke wheels (standard 10 spline) for the the B I'm working on and I am planning on removing a new set of 11.2 X 36 tires off a set of flat spoke cut offs that I already have. Today I got to looking at all of this and I'm not sure the tires will fit. How do you measure a rim for tire fit? The inside rim (where the bead would sit) looks about the same but the round spoke rims have a lot taller rim making the overall wheel size larger, so I don't know. Any guidance would be appreciated.
Clooney
02-24-2002 17:39:37
 Re: FH Spoke wheel tire size in reply to Bguy, 02-24-2002 17:13:18
third party image
Bguy, the rim is measured at the rim point where the tire bead seats, see "B" in the attached drawing. The vertical "B" is diameter & the lateral "B" is rim width. The "I" is wheel offset.
Bguy
02-25-2002 19:01:41
 Re: Re: FH Spoke wheel tire size in reply to Clooney, 02-24-2002 17:39:37
Clooney, Thanks, that explains that. I measured my wheels and dimension B is 6 inches and vertical B is 36 inches. That means I need 9.5 X 36 tires, right? I looked at the listing on the Miller tire site and that's the closest size they show.
