STEEL BALLS IN CARB
Ben.SoTex
02-24-2002 11:14:43
How do I get the steel balls out of the carb, JD 60 CARB GAS
Clooney
02-24-2002 16:59:33
 Re: STEEL BALLS IN CARB in reply to Ben.SoTex, 02-24-2002 11:14:43
Ben, those little passage plug balls can be a real pain to remove.
~I have tried a few different methods & have found none that are fool proof.
~The last few I have done I used my acetylene torch with a fine tip to heat the balls to a dull red, then after allowing to cool drilled them out with a small drill bit (it took a few bits to get through the balls).
~I have also used a Dremel to grind the casting above the balls just slightly larger (basically just cleaned the casting above balls) then used my mig welder to weld a small tail on the balls & pulled them with a pair of side cutters, this takes a steady hand & good welder with .025 wire.
~If this seems a little extreme for you, you might try your local machine shop to see if they can remove them for you with their broken tap removing equipment.
Ben.So.Tex
02-24-2002 18:03:00
 Re: Re: STEEL BALLS IN CARB in reply to Clooney, 02-24-2002 16:59:33
Thanks Clooney,,I had a plug passage on my 60 and had to keep the choke out alittle for it to run,I managed to get a small copper wire and force it in the passage with needle nose pliers. it broke the crud free and now it run good.I am sure glad I didnt have to remove the ball to clean the passage, My eyes aint what they use to be nor my steady hand.THANK YOU.. BEN
