John Deere M, what's it worth?
Chad C.
02-24-2002 10:52:35
I know yall get asked these kinda questions all the time, so forgive me for asking again. Runs okay, needs a little carb work, hydraulics good, seat not original and in poor shape, rear tires-good tread, but cracked, front tires poor, paint okay. Comes with cultivators, plow, and disk, though these haven't been used in quite some time, have been sitting out and rusting, condition of bearings unknown, but everything spins so lets just say that they are good. Starts right up and charges, smells like some gas in engine oil, that's why I am thinking it might need a rebuild, radiator real good, brakes and clutch real good. What is a fair price to pay for this machine, it's in Maryland, and what is the most someone could ask and get for it? Thanks.
V
02-25-2002 17:35:23
 Re: John Deere M, what's it worth? in reply to Chad C., 02-24-2002 10:52:35
I have seen John Deere M tractors sell for as much as $3-4 thousand if they are cleaned up and running good. That disk is kinda rare and hard to find, providing it is a lift disk designed for that tractor. $1,000 for the disk alone I have seen at used tractor dealers.
Chad
02-25-2002 07:54:00
Thanks for the info. I was thinking somewhere around 1500 or so, I wanted to make sure I wasn't way off in one direction or the other. Thanks again.
JDM Guy
02-25-2002 04:08:31
Chad,
You could maybe get 1500-1700 sense it drives and has power. My M was the same way, bad tires, bad carb, stored out side, clutch was broken, gas in oil. All i did was rebiult the carb and put new front tires on.
Stacey
02-24-2002 16:42:53
in Maryland, that tractor with impliments is worth $2000.00+
Let me know
Stacey
JDM Guy
02-24-2002 15:08:21
Chad,
Well to get to the point I would sell it for 1000. You most likely will need to do a engine rebiuld for the gas smell. Tires are pretty hard on the $$$. Carb work is not to bad. Does the tractor drive? With cultivators, plow, and a disk you could get some money. Was the tractor stored out side?
Chad
02-24-2002 16:28:03
 Re: Re: John Deere M, what's it worth? in reply to JDM Guy, 02-24-2002 15:08:21
The tractor had been stored in and out, but has been in for the most part. Drives great, seems to have plenty of power, doesn't smoke at all. Thanks for the input
Dan
02-24-2002 21:07:47
 Re: Re: Re: John Deere M, what's it worth? in reply to Chad, 02-24-2002 16:28:03
Gas in oil may be due to carb problems, those verticle 2 cylinders tend to pull more fuel into the #1 cylinder due to shape of the manifold so if carb is having problems it causes too much fuel to go to that cylinder. Quite often will foul plug also.
michael solan
09-03-2003 09:23:30
 Re: Re: Re: Re: John Deere M, what's it worth? in reply to Dan, 02-24-2002 21:07:47
Still have the M?..... Please let me know...I live in Pa....Will make reasonable offer! Thanks, Michael Phone...814 692 8291
