Just got my new A home
Alan
02-24-2002 09:13:18
Neighbor hunted me down and sold me a 1950 model A for 100.00 we pulled it a half a mile home its stuck from siting outside but everyting is straight on the tractor cant wait to get it in the shop. The clutch is stuck how is the best way to go about getting it free the lever moves but it fells like its stuck down inside just wanted to share this with you guys happy as a kid with a new toy.
Jerry S
02-25-2002 09:29:06
 Re: Just got my new A home in reply to Alan, 02-24-2002 09:13:18
On the clutch being stuck, What I would do is take the pulley cover off and spray it down with some WD40 or your favorite rust remover. If you can engage and disengage the clutch, then you have to have a pad sticking in it I would think. Look at it to see what you have as someone moves the clutch. Take the adjusting nuts off and keep removing clutch pieces until you find what keeps the pulley from moving. If you don't see something once you take the drive pulley out, check the fork that comes out of the front of the first reduction gear to make sure it hasn't broken. It is a brass piece that could break. Is held in by 4 bolts.
NJS
02-25-2002 09:23:26
Alan,
The reason no one comments on your good fortune is that we are all jealous.
Alan
02-25-2002 17:14:01
 Re: Re: Just got my new A home in reply to NJS, 02-25-2002 09:23:26
Well just got home and still trying to get it unstuck maybe I was not so lucky but I will keep working on it to I get it all loose and working again I cant junk it the Tractor club Im in would dis own me lol.
Larry W.
02-26-2002 06:21:07
 Re: Re: Re: Just got my new A home in reply to Alan, 02-25-2002 17:14:01
Do you live where it freezes? If so it may be there is ice in the transmission and clutch drive. Best to let it thaw and drain everything befor you take it all apart. I had one one time that had a lump of ice in the clutch gear oil pan drain area. I am not sure what it's called. Anyway, it kept the clutch from disengaging and also kept the engine from turning over. When it warmed up, it all worked.
